Bst.Price On Brand NewSUV?Negotiate Before Rebate?
by crazyoildude
07/27/16 12:12 PM
Fram 3675 vs 3506?
by Wasatch1
07/27/16 11:20 AM
Oil Filter Q? Part 2
by BlueOvalFitter
07/27/16 10:54 AM
0W20 in the Ranger?
by iambretto
07/27/16 10:11 AM
Sears/Kmart DieHard Gold 40R on sale 50% off
by slacktide_bitog
07/27/16 10:11 AM
Motorcycle tire repair out on the road, best kit?
by LoneRanger
07/27/16 10:11 AM
Weedeater air filter oil???
by Drew99GT
07/27/16 10:08 AM
Brand Comparison between 5w-40 vs. 15w-40
by mbacfp
07/27/16 10:07 AM
Friend only wants to do what he wants?
by motor_oil_madman
07/27/16 09:58 AM
LC9/LC9S Slide Wear
by Hokiefyd
07/27/16 09:51 AM
MaxLife ATF use where ford Mercon V call for ?
by MetalSlug
07/27/16 08:41 AM
Your FINAL though on Quaker State oil line
by MetalSlug
07/27/16 07:45 AM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
93 registered (2015_PSD, AirgunSavant, 901Memphis, aquariuscsm, Alfred_B, 7 invisible), 1994 Guests and 13 Spiders online.
58613 Members
66 Forums
252311 Topics
#210536 - 04/15/03 11:08 PM Understanding Schaeffer’s Grease Applications
darrenc Offline
Loc: West Coast
Bob,
Can you give us all a brief description of the following Schaeffer’s greases and their applications and/or where they should not be uses:
#221 Moly Ultra 800 EP
#222 Moly Wheel Bearing Grease
#229 Moly Ultra Red EP
#238 Moly Supreme
I understand some of the differences. For example, I understand that 238 should not be used for wheel bearings due to its higher tack, but that it is good for chassis lubrication. And I know that 221 is a good all around grease; however, I'm confused about the roles of 229 and 222. Why use 222 or 229 over 221, for example. The Schaeffer's tech sheets are not particullarly enlightening is this regard. Thanks.
#210537 - 04/21/03 09:07 AM Re: Understanding Schaeffer’s Grease Applications
darrenc Offline
Loc: West Coast
Oh Bob.... [Cheers!]
#210538 - 04/21/03 11:47 PM Re: Understanding Schaeffer’s Grease Applications
68redlines73 Offline
Loc: SF/Bay Area, CA
I'm not Bob, but I play him on TV (kidding!)...
  • #221 Moly Ultra 800 EP - Well-rounded automotive/industrial aluminum complex grease with solid moly and other EP additives. Wide range of grades to choose from. Petroleum base oil. Tackified. Least expensive in the group.
  • #222 Moly Wheel Bearing Grease - Only available in NLGI 3 - Hard to discern any differences from #221 other than name.
  • #229 Moly Ultra Red EP - Should be an excellent, all-around aluminum complex grease. Contains soluble moly vs. solid moly. Also contains teflon. Not tackified. Petroleum base oil. Only available in NLGI 1 and 2 so very automotive-focused. Should be the second-most expensive in the lot.
  • #238 Moly Supreme - The winner for the most diverse set of additives! Also should be an excellent, all-around aluminum complex grease. Contains soluble moly vs. solid moly. Also contains teflon and graphite. Petroleum base oil with about 10% PAO. Tackified. Wide range of grades to choose from. Should be the most expensive in the lot.
How'd I do, Bob? Scheaffer's definitely needs to review their online spec sheets. A bit too much cutting and pasting went on. [Smile]
#210539 - 04/22/03 01:10 AM Re: Understanding Schaeffer’s Grease Applications
darrenc Offline
Loc: West Coast
69Redlines73,
I came to the same conclusion as you. Lots of cutting and pasting and little to distinguish one from the other. Thanks for the attempt!
#210540 - 04/22/03 03:02 AM Re: Understanding Schaeffer’s Grease Applications
BOBISTHEOILGUY Offline
Loc: Ocala, Florida
Nice job redline.
Actually, I haven't taken the time to go into each one of these. The reason is I have a select set of greases I use/recommend and it keeps it simplier than to sell all of them. As you can see, many are basic duplicates of each other.
#210541 - 04/22/03 03:57 AM Re: Understanding Schaeffer’s Grease Applications
Bob:
I know we've seen your various grease recommendations in a variety of posts but could you repeat the consolidated list here one more time?
68redlines73
#210542 - 04/22/03 04:14 AM Re: Understanding Schaeffer’s Grease Applications
darrenc Offline
Loc: West Coast
Yes Please! I know 221 is your favorite Bob. I now have 2 tubes of this stuff and have repacked the wheel bearings on my boat trailer with this grease based on your recommendation. Thanks. I trust just about anybody from Florida on boat related issues.
Darren
#210543 - 04/22/03 06:28 AM Re: Understanding Schaeffer’s Grease Applications
Cressida Online   content
Loc: Joplin
Yes it would be helpful - as I remember Bob uses the 238 but recommends 221 for those of us North of Florida. If you are going to get just one for wheel bearing and chassie lube will either do fine?
