Great site!! Finally registered after months of reading. I need to know what a good substitute grease would be for my 1998 75 HP Mariner outboard lower jet unit, it has zert fitting right on the jet housing for load carrying bearing lubrication.(Lubed after each fishing trip per/manual) Jet unit factory sent Lubriplate No. 630AA grease w/unit when new, I have run out after three yrs of use, parts stores in this area don't carry Lubriplate, any suggestions?? Motor turns tops of 5500 rpm, needs to be highly water resistant. I have started using Sta-Lube Super white but not sure its good enough of a replacement.
