Does anyone have any thoughts on the shelf life of aluminum complex grease? Under what conditions will they store better?
I've switched to Schaeffer's #238 Aluminum complex grease. Very pleased with the results. One pleasant side effect though. Case of grease is 30 - 14.5 oz tubes. Using lithium I used around 18 to 20 tubes a year.
The aluminum complex Schaeffer's stuff is cutting that consumption in half. That means 30 tubes of grease will last 2.5 to 3 years.
