Hello,
I own a Honda Passport, and I'm trying to decide which oil to use in the transfer case. The owner's manual says to use a 5W-30 motor oil. The two oils I was thinking of are Rotella T5 10W-30 and Pennzoil Ultra 5W-30. I'm trying to select a beefy, robust oil in hopes of reducing the wear and tear in the transfer case. What do you think of my oil choices?
I like T5 because it was designed to be used in heavy duty applications, but, I'm concerned with it being a 10w instead of a 5w. Would it really affect the operation of the transfer case when I go to use 4-wheel drive in the winter?
Would the Ultra be robust enough to cut down on wear? Thanks!
