Could you please post what you used before T6, and what your fuel mileage has been with both (or more) oils?
I think this may just be the holy grail oil. We know it can handle the extreme heat and low speed loads in HDD engines. I was concerned about how well it'd work in high-speed gasoline engines like high-output Honda I4's, but since it meets the JASO MA spec for motorcycles, this probably won't be an issue at all. All that's left to determine is how much of an impact there will be on fuel consumption for the extra protection. The other two oils that have made it to the final round are PU 5W40 and M1 0W40.
