Originally Posted By: eagle23
I have the RE960's on my 2007 Accord V6. It's a different size from yours but I will definitely buy it again. They are really good in the dry and wet....that was worth a lot to me. I have almost 40k on them now and expect to see 50k+.
The predecessor to the RE960 was the RE930. I had a set of those on a 1995 V6 Camry, and were the first set of tires I'd had in years that I promptly bought a second set when they wore out. The RE960s seem to be in that tradition.
As I understand it, and I may be wrong, the MXV4 is more a high mileage tire. If that's what you value more, it may be the better choice. But considering how well the RE960s wear and perform, they still come up as the better deal...for me.
If you're reading Tire Racks' reviews they are very helpful.
Litterally: your mileage may vary
I doubt you'll be unhappy with either one.
Actually, they the RE950s that the RE960AS PP replaced. And I was a little disappointed in them as well - but I upped my tire pressure to 35 instead of 30 and I saw a good increase in MPG this tank. I think Costco stuck to Lexus specs even though I'm running Plus 1 fitment and they originally said 35 is where I should be at.
