Originally Posted By: CATERHAM
When replacing or rotating tires, obviously the tires with the most tread always go on the driven axle or the axle with the greater power bias.......
Not only do I think it is not obvious, I think it is wrong!
.....It's the reason road racers can increase the rear brake bias in the wet.
Actually the reason they increase the rear brake bias is that the weight tranfer is less so the fronts are even more prone to lock up first - and that's a good thing if you don't have the ability to adjust the brake bias. But if you are after fast lap times, you'll get just a bit more braking action in the wet if you do that.
But in the final analysis of street situations, you should put the best tires on the rear so the rears NEVER lock up first. Even if you are just braking in a straight line, you'll want the rear to always have more traction than the front. Otherwise, the rear wants to become the front.
The only exception to that is when you are accellerating on snow. In that case having the better tires on the drive - the front if a FWD - will get you going better. Unfortuantely, it's just the opposite of what's good when you are braking.
