Originally Posted By: dnewton3
Originally Posted By: chevrofreak
[This does not take into account that the temperature these oils are tested at for cold cranking is determined by the winter number. A 10w is tested at a different temperature than a 5w or 0w, so direct comparison of the numbers is not possible.
Per the ASTM website:
http://www.astm.org/Standards/D5293.htm
The correlation between CCS and apparent viscosity and engine cranking was confirmed at temperatures between –1 and –40°C by work on 17 commercial engine oils (SAE grades 5W, 10W, 15W, and 20W). Both synthetic and mineral oil based products were evaluated. See ASTM STP 621.
A correlation was established in a low temperature engine performance study between light duty engine startability and CCS measured apparent viscosity. This study used ten 1990s engines at temperatures ranging from –1 down to –40°C with six commercial engine oils (SAE 0W, 5W, 10W, 15W, 20W, and 25W).
It's hard to distinguish from the abstract summary, but it looks as though the light winter grades were all tested to the same standard. Since I'm not familiar with the test, I cannot comment in that regard. At $39, I'm not going to purchase the report. But what it appears to possibly state is that all the differening grades were tested in that total range (-1C to -40C). I would presume the whole point of the test was to see how different grades reacted in cold-cranking ability, comparing one to another. If they tested at different temps and did not cross-test between winter grades, I would agree that the data would not have direct corelation, but then I'd also have to say the test was a big waste of time as well because I would expect for a 10w-xx to crank about as well as any other 10w-xx, dino to dino, syn to syn.
Regardless, here's what I'm trying to point out ...
The T6 5w-40 and T5 10w-30 both have the same cold cranking rating. Even if there were a temp difference in that cold crank set-point, would it equal the price difference in a performance/dollar ratio? In other words, if the 10w T5 was crank-rated at -15 deg and the 5w T6 was rated at -25 deg, do you get a 50% lower temp in crank rating for the 50% cost increase (or more) in the purchase price when you upgrade to T6? I surely don't see that happening.
There are some people that live in really ugly-cold, super e-x-t-r-e-m-e areas. But that's not most of us, and that's not the "cold" that the OP was speaking of. He merely was pointing out how well the diesel cranked over comparing the T5 to the dino 15w-40. I can believe that. But I can also believe that the 10w-30 dino is "better" than the dino 15w-40, and I can believe that the T5 10w-30 compares nearly (if not equally) as well for a lot less cost than the T6. And for most of us, even in the cold of the US, we don't need the added expense. I don't know about you, but I like to get my money's worth. I don't see a minimal (or non-existent) cold-crank temp gain worth 50-60% more money. In the OP's area, the 10w-30 T5 will do every bit as well at the T6 for a lot less money.
If it's that gosh-darn cold in your area where temps are below -35 deg C on a routine basis, then I'd tend to favor a quality PAO 5w-30 HDEO such as Amsoil or perhaps Elixion.
guys ,,,u all are splitting hairs and shaven whiskers,,run the 5w40 and have a nice day,,we or me aint inpressed,,way to much info............lol IMHO and so on ,,,,sky
