That leading post is confusing, at least to me ...
Let me start by offering an apology, because I'm going to be a bit critical, and don't mean to offend you.
Are we to assume that "mi" is total miles on the vehicle, and "oil" is total miles on the oil? If so, your numbers are messed up, to be blunt.
At 108K miles, you had 10k miles on the oil? You then accumlated 6k miles on the truck to get 114k miles, yet you only had 14k miles on the oil (a differnce of only 4k miles). How did the truck get 6k miles but the oil only get 4k miles? Then 12.6k truck driving miles later at 126.6k miles, you show 14k.6 miles on the oil? How did the truck get 12.6k miles but the oil only get .6k miles (only 600 miles)?????? The only part that made sense to me was that the last 8k miles on the truck matches up with the 8k miles accumulated on the oil.
You have one Ni entry, but four for Cu? Then towards the end you show "Ni" with four entries. Are you trying to differentiate between Nickle and Nitrates?
The "Cu" (copper) seems a bit odd to say the least. You start with 20, then double to 40, then nearly double again to 74, then more than double yet again to 184! It's normal to accumlate wear metals with mileage, but that should be typically in a somewhat linear fassion; your's is on a parabolic rise! At that rate, (presuming the numbers are correct, which is a big stretch of faith here) you're already in danger. Either something is wearing badly, or you're having a very agressive chemical reaction.
Your TBN drops, then rises (as if there was a top-off or OCI?), and then drops again?
Is "Crom" supposed to be your Chromium? Is that two numbers "11" and "12" or four numbers "1", "1", "1", "2"?
Was this all one load of AME and your numbers are messed up? If not one load, were these all AME? Were there other brands/grades? Was this the first load of an Amsoil product?
Why are you using hyphens ("-")between some numbers, but not others?
What lab services were used?
I just can't make sense of this initial post.
Please, re-enter your data in a fassion sillilar to this below, using the "dots" to seperate your data, and try to make the columns line up, please.:
oil brand.............ABC.............BCD................CDE.................DEF
oil grade............yw-zz............yw-zz..............yw-zz................yw-zz
truck miles ....... xxx,xxx .........xxx,xxx............xxx,xxx.............xxx,xxx
oil miles..............xx,xxx..........xx,xxx.............xx,xxx..............xx,xxx
wear metal ............xxx.............xxx.................xxx................xxx
wear metal.............xxx.............xxx.................xxx.................xxx
TBN....................xxx.............xxx.................xxx.................xxx
Vis....................xxx.............xxx.................xxx..................xxx
etc,
etc,
etc.
And double check your mileage numbers, please. Your math does not add up.
