Symptoms:
At idle, there is no detectable power assist.
Parked at 1000 RPM steering works fine, except that if I hit the brakes while turning the wheel, the wheel stops turning for a second then resumes.
On the highway, there is too much power assist and it wants to steer itself, it seems like you turn it just enough to change lanes and the wheel wants to keep turning that direction, you have to hold the wheel tight or it will keep turning. Doesn't seem to center itself.
Vehicle: 1997 Suburban 4WD, 454, hydroboost, variable assist power steering. I have flushed the system, replacing most of the fluid with zero change.
