When driving at 65, and light braking to 50, a terrible shake comes up through the steering wheel. problem is, it is intermittent.
I had the front brakes replaced, and rotors machined at toyota dealer. Because prior to that there was always a vauge shimmy through the wheel when braking.
After the work, everything feels fine 99% of the time, but on the highway, out of the blue, this would happen. at one stage i was really worried because the vibration became quite violent!
From reading the Haynes troubleshooting guide the only thing i can think of is the wheel bearings. the car only has 60,000 miles on it.
Maybe one disc is chattering and grabbing a pad so there is a differential effect from the driveshaft, making the steering shake, but that would mean a part of the new pad is welded to the disc, on at least one of the 4 sides of the two rotors.
if i brake mroe heavily the vibration generally goes away.
Love this car but I don't trust the front brakes/steering/suspension... any thoughts?
