I have a Johnson 27 loader on a John Deere 318 garden tractor. The loader was probably made in the early 1980's. The loader manual indicates to use 10w30 motor oil (MS) in the hydraulic system but also says type F ATF can be used. Currently it has some type of ATF in it (its red). What would be your recommendations, use motor oil or type F. It has a cessna hydraulic pump. It will be used in fairly cold weather in central illinois, but it also gets hot here too.
Thanks,
Bill
Thanks,
Bill
