I was just browsing the LM website and noticed they have some new products, or at least new packaging. I hope LM isn't becomming a Me-2 company.
Quote:
CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil.
Visco-Stabil looks like STP oil treatment
Quote:
Visco-Stabil
Reduces oil consumption. Stabilises the viscosity of the oil. For,constant oil pressure. Visco-Stable also offers outstanding protection,against loss due to mechanical shear of the engine oil under the,hardest running conditions. Prevents engine-oil thinning in the event of frequent cold starts. The,oil consumption is reduced by the improved sealing of moving engine components. For this reason, the product is specially suitable for older cars. Reduces noise from hydraulic lifters.
They changed the name of the MOS2 additive. data sheet shows
Quote:
Oil Additiv
The anti-friction lubricant MoS2 forms a high load-bearing film of lubricant on all friction and sliding surfaces. This product reduces friction and guarantees energy-conserving performance for the unit. This yields the following advantages: significant savings in fuel and oil consumption, scientifically proved reduction in wear, fewer break-downs, emergency lubrication properties. Tested on catalytic converters and turbochargers.
This seems interesting
Quote:
Hydro-Stößel-Additiv
Damps the noise produced by worn hydraulic lifters. Cleans valves and holes in the lifter and promotes optimum operation.
Quote:
Visco-Stabil
Quote:
Oil Additiv
