As you may know from my other post, My husky lawn tractor quit functioning. After consideration of the cost of a new tractor, and the cost of parts to rebuild a motor on my own, I decided to pull the engine (intek I/C 17.5 horse, one cylinder, vertical shaft) and see if what was wrong was fix-able.
The symptom after the engine quit working is that it wouldnt start (duh), when I tried to start it back up, the starter would just spin the crank, relatively fast, like there wasnt resistance.
Well, I pulled the motor, thinking that something in the bottom end was not connected, and I might need a new rod or crank or something similar. During my teardown, I pulled the head off and noticed that the Intake valve was stuck open. There was so much crud on the valve stem, that it did not want to seat. I could see light all the way around the valve and knew this wasnt good.
I cleaned the valvestem and reinstalled, it now seats and functions smoothly.
While I had the head off, I played with the crank and noticed that the piston moved up and down with ease, and that the bore looked fine- I did not have time to pull the flywheel and get a look at the bottom end last night.
When I reinstalled the head, I made sure that the valves were functioning properly by turning the crank and viewing the action. - All ok
I noticed however, at this point, that I could still turn the crank by hand with the flywheel and PTO even through the compression stroke (was slightly more difficult than before).
Should I be able to turn this by hand? I'm wondering if this means I don't have compression?
Also, is there an adjustment to the valves that i need to do?
