Originally Posted By: Pablo
I like Windows 7 quite a bit. Vista is fine for me too - I'm using it now (4 years?)!!. I know it bugs you so called pros that people actually didn't mind Vista, but it never crashes or locks up on me like XP. I have 7 PC's and a host of other devices in my network, all is well except the XP wheezer.
I started this world in DOS 2 then 3.X. Then ALL the versions of Windows. I even had ME for near 4 years, with no real issues. But of all the post Win 3.1 OS's, XP is the worst. Just clunky and irritating. Stupid and not that configurable other than the MU junk. Wavinwayne summed it up.
Anyway there are couple of reasons why I can't go to a single user right now. Just want to get rid of the pop up message. No way to turn it off?
So called pro's? Really? So I am to assume you took your CCNA, MSCE, RHCE, BSC, [censored] you've probably got your CCIE too right? Or was that just a personal jab for the sake of it because you are frustrated?
BTW, I remarked in another discussion we had on Vista that I had no personal dislike for it either. After all, Vista was simply a fork of the product that became known as Windows 7 (I know that sounds backwards). So it is no surprise that in functionality they are similar. 7 is simply more refined, and subsequently lighter on resources. I've had no issues with Vista personally either. Other than on the same hardware, 7 is noticeably faster.
XP is structurally very similar to the two OS's you are contrasting it to. Instability issues on NT-based OS's come from two sources: hardware and drivers. Either the hardware it is running on is junk. Or the drivers for the hardware it is running on are junk. It is really that simple. Lock-ups and crashes stem from those two things.
XP is definitely less "refined" in terms of user interaction than Vista or 7. Given the time rift between its development and theirs, I would hope there had been improvements in that area. In terms of core structure, they are ALL an improvement over the 9x-series OS's by a WIDE margin. Even if your experiences have led you to believe otherwise.
Anyway, the "feature" you are experiencing is one that is supposed to let you run an application as another user on the system. To disable it, go to Control Panel -> Administrative Tools -> Services -> Secondary Logon -> right-click, properties -> Stop. Set to disable.
Reboot.
Should be gone.
