Lets say better protection instead of wear.
HT/HS or "High Temperature/High Shear" (ASTM D-4683) is an rating that determines the oils stability in a high temperature, high stress conditions. The oil's ability to withstand shearing and tearing is very important especially in a high RPM engine. The oil's ability to protect bearings, cylinder walls and rings, connecting rod bearings, main bearings, cam lobes and lifters, etc. is vital to an engine. For an oil to pass the ASTM D-4683, an oil must have a protective viscosity of 2.9 cP at 302 degrees F. The HIGHER the number the better!
I think for most street engines driven as such it makes little difference.
