JHZR2
Staff member
Hi,
Ive searched here and on the interweb, but have never found a good, concise explanation of drill bits.
Long story short, I need to drill a hole in some 3/4" thick pieces of wood. The hole would be about 3/4" in diameter.
Ive always used "standard" drill bits for various things, but there are other kinds. A 3/4" drill bit is quite expensive.
I noted that there are spade bits, and then augers and "super spades" which are like three spades with an auger behind it. There are also fancier bits for making really nice holes.
So my questions are:
-when do you use a spade bit versus a regular bit?
-will a spade bit ruin the wood on the side where it comes out due to ripping the wood?
-Does a more brittle standard bit, like a cobalt bit make any difference if drilling something soft like a new 2x4? The chart at HD said cobalt bits were not recommended for wood, just metal.
-Why would you use an auger over a spade, or just a longer regular bit?
-When would you use a hole saw versus a big spade bit for wood?
I can see that there is a benefit for the augers and spades for getting them centered perfectly, vs standard bits which can walk a bit. However Ive never really had an issue if I made a small indent with an awl and/or made a smaller initial hole. If placement isnt a huge issue, does any of this really matter? Are spade bit just a far cheaper way to make holes once the holes get larger tan 1/2" which is the end of available and cost effective bits?
Thanks very much!
Thanks very much!
