Originally Posted By: Back40
This is my daughter's car. She called yesterday and told me the battery was dead after being parked about 3 hrs from returning from the doctor. She had it jumped and said the alternator light in the dash was not illuminated and drove to Autozone where they provided the 13.2 voltage reading and suggested the alternator. I will be heading over tonight with my battery charger and multi-tester. If I confirm the voltage output at 2000 rpm is low 13s then I guess it's time for a rebuilt altenator.
(removed insult)
It is possible your alternator is only providing 2/3 or 1/3 or it's ability, but I do not think so. I think your alternator is fine and it is the battery which is weak/ old/ sulfated and definitely undercharged.
If a battery needs a jumpstart, it was obviously near dead. The vehicles charging system will need Hours and hours of driving before it can fully charge a battery. There is no way around this. A battery can only accept so many amps so thinking an 85 amp alternator is recharging the battery at even half that rate for any duration is unlikely in the extreme.
The battery might have been 30% charged when Autozone took a 13.2 reading. If they had revved the engine they would likely see the voltage climb. 13.2 volts at idle speed with a severely depleted battery is to be expected. At Idle speed the alternator might be able to produce 30 to 40 amps. This is not enough to bring the voltage above 13.2. After 10 minutes, sure the voltage will start to rise more. As the battery increases in charge the voltage will rise. When it gets to the factory set point, the voltage regulator will start asking less of the alternator to keep the alternator from bringing the battery voltage above the setpoint, which will change with temperature.
Also the opposite is true. When the battery is at or very nearly fully charged, the voltage regulator will drop the voltage to 13.2 to 13.6 so as to not overcharge the battery and cause excessive water consumption.
Whenever a battery needs to be jumpstarted, it is best to plug it into a regular 10 amp battery charger overnight. If after doing this, the vehicle needs another jumpstart again, the battery is done.
If the vehicle is only driven less than an hour after a jumpstart the battery is still likely below 50%. It will have enough juice to start the vehicle, but anytime a battery is sitting below 80% charged it is sulfating, losing life and capacity. SO a bunch of short trips never will get th battery above 80%, the battery dies early and the owner blames the vehicle or the battery.
