Originally Posted By: Bob Woods
After my experience with a Mitsubushi self destructing engine I will never again buy a car with a timing belt. Even cheap ole saturn was smart enough to use a chain.
Similarly, I'll never buy one with a timing chain. Belts are quieter, more dimensionally stable and designed to be replaced fairly easily. YMMV.
Originally Posted By: Chris Meutsch
You clearly know 1000% more than I do about modern VW's and I totally respect that knowledge. Your entire post here would simply scare me to death if I was interested in a diesel VW (or a gas version) for any reason.
TDIs are excellent cars that work wonderfully when maintained correctly, but quickly turn into nightmarish junk when neglected. Both of mine are great, but they get maintained well.
Originally Posted By: Bluestream
Thanks for all the input. I was told all work for the timing belt/water pump was done at the VW dealer. Also, that an aftermarket belt kit was used that is suposed to last twice as long as the VW belt. Not sure if he got this right, but he said it was good for 200K KM
In Canada, dealerships are much better about TDIs as y'all have many more of them - but in the states, the dealership is the LAST place you want working on a VW.
It's clear the PO doesn't know what he's talking about, and I would pass on this car. The VW belt system is rated for 160k km and no aftermarket belts claim anything higher than that from what I've seen, unless they're lying.
Originally Posted By: ls1mike
These are my favorite threads because I had an 02 TDI and guys will defend the TDI until death, but I have seen some of the same guys bash having to do an intake manifold gasket, here my take is. Not worth the headache. I have have had mid 80's turbo Dodges that required less maintenance then my TDI. Here are a couple of shots of carbon build up even with proper oil and proper fuel with 4000 to 5000 mile oil changes with 505.01 spec oil.
Like I said, I enjoy my TDIs and many others do as well but they are very intolerant of lack of maintenance and unfortunately the stealership is usually behind incomplete or shoddy work.
FWIW, the stock OCI & oil specification was 10k miles and 505.00. Plenty of folks had intake clogging issues with them because they drove trying to squeeze out every miserly MPG they could. Bad for the intake & turbo vanes.
Some folks are not a good fit for some cars, and I'm glad you're in a vehicle that suits you much better now.
