I have a vehicle that takes a P235/65R17 tire, and am looking to put new tires on it. I'm looking at the P235/65R17 and the P245/65R17 size. And I'm looking at two different tires here, one in the P235/65R17 size, but a different tire if I elect to go with the P245/65R17 size.
The P235/65R17 is 29.1" tall, has a 9.5" section width, and weighs 32 pounds.
The P245/65R17 is 29.6" tall, has a 9.6" section width, and weighs 31 pounds.
I'm not interested in the differences in the performance of the two tires for this discussion; I'm interested in which tire would be preferable in terms of load on the vehicle/suspension, etc. You typically want to minimize unsprung mass to minimize load on the suspension. And taller tires generally add load to the drivetrain. These two are not normally at odds like this; the larger tires are typically the heavier ones. But in this case, the "larger" tire is barely larger to begin with, and the weight is actually a pound less.
Which should I consider to be the most critical here: tire diameter or tire weight? I don't want the discussion to turn into a vehicle or tire brand discussion, but let's just say that this is a 4-door SUV with 4-wheel independent suspension that doesn't see severe duty, but does ocassionally go off the pavement and tow.
