I looked at that quite a few years ago when learning about bio diesel and how to make etc. IMO you cannot get around the steps of esterfication and washing that making real home bioD takes. To much of a gimmick, what you will likely end up with is injection pumps and injectors clogged with a nasty wax build up similar to what you get running straight WVO without processing. Not even taking into account EGR valves, cats, and DPF. You should be able to find archive discussions on Diesel Stop, or Diesel Site or some of the other Diesel forums from about the 2001 to 2004 time frame with scads more discussion on that very product. Most steered way clear of it. IF you contemplate running SVO, you probably need at least a two tank system, and some way of preheating the oil before feeding to the engine, this is not for the faint of heart and be ready to accept all liability of what you do.
I used to be able to find some pics of gunked up pumps but not sure where they are, but there are some out there somewhere on the net.
Some quick sites that can start you on research:
http://www.cumminsforum.com/forum/altern...esel-ctd-3.html
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/419605551/m/2901017112/p/1
http://www.flashoffroad.com/Diesel/DieselFuel/bioDiesel.htm
http://journeytoforever.org/biodiesel_TDI.html
http://journeytoforever.org/biodiesel_svo.html
http://ctbiodzl.freeshell.org/votdi.html#FAQ
http://www.dieselplace.com/forum/forumdisplay.php?f=64
Here's a good quote from
http://forums.tdiclub.com/showthread.php?t=245955
Quote:
Tell me more about Biodiesel and veggie oil…
Biodiesel will shorten the life of the pump, that much is certain. If you have proper filtration, good quality biodiesel, and don’t switch back and forth with regular diesel you should get a good 120-150,000 miles out of a pump. Often biodiesel pumps are good cores and have no problems with rebuilds. The exception is the home brewers that don’t get all the water out which rusts the pump out from the inside.
Grease/veggie oil gums pump the pump. When you open it up it looks like syrup in there. The positioner sticks, as do the sliding sleeves which all combined contribute to the pump failure. Because of that anyone who runs veggie oil can count on a core being completely junked. Sometimes in rare cases they are ok, but this is the exception and not the rule. In my experience most people have their veggie oil pumps fail at 60-80,000 miles. Some have gone more than twice that, but they are very particular about how they use their veggie oil. Remember we’re talking about my average experience over a good 200+ rebuilds over the years.
So in conclusion, if you have proper filtration, don’t have water going through the system, don’t run biodiesel or grease, and run a properly lubricated pump then your pump should last indefinitely. I have customers with over 500,000 miles on the original pump. I’ve heard of a couple older A3/B4 pumps that lasted over 700,000 miles. However, in my experience most A3/B4 pumps last about 200,000-250,000 miles before needing a rebuild. Most A4 ALH pumps last about 175,000-200,000 miles before needing a rebuild. Watch for the symptoms of a bad pump, and then take care of it soon to avoid a good core from being turned into a junk core. If you’re close to a timing belt change you might as well do that at the same time too.
