Originally Posted By: 901Memphis
Originally Posted By: BRO1
Would Rotella T6 5w40 be good oil to run in my 08 silverado with the 5.3L motor?
It has 18000 miles on it?
Thanks
Isn't that a little thick for your OEM specs?
That is what worried about it being to thick,but I do a lot of towing with it also that is also why i'm asking.
Thanks
Stick with the 5W/30 or go to 10W/30. Go sythetic if you want the extra margin of safety. I think the thicker 5/40 would create slightly more drag and heat and that's not what you want. You want all the power. Not saying you'd ever notice this or that it's bad - I just know that the factory has spec'd 5W/30 based on several requirements of which holding up to high heat and towing is one of them. I run Mobil 1 5W/30 in my Sierra 6.0L and I'm happy. If I am towing a lot in the summer, I'll use the 10W/30 version but doubt there's any great benefit.
