Maybe I can help on this one! I work at O'reilly's , and I can tell you that it is bottled by Omni down in Louisiana. O'reilly conventional and synthetic motor oils consist of basestock oils purchased from the big companies such as Ashland , Sopus and Mobil. Additive packages are from not from them but from smaller independent additive formulators. Pretty much they meet all the required specs for a SM oil however are they great oil's , not really. The conventional is a Group II basestock as far as me and my coworkers know and the synthetic is a Group III , the conventional oil should be good for 3k miles but i wouldnt put it much past that . The synthetic has a very similar looking formula to Valvoline Synpower so possibly it is Ashland basestock and Additives perhaps. In the end they are housebrand oils and perform to current minimum specs , they cant be expected to be Mobil 1 or PYB. Overall not a bad value for the person needing a oil change or top off when the wallet is hurting.
