Hello all.
I just bought a 2006 WRX. The build date is February 2006 and I bought it early August 2006. It had 51 miles on it as a test drive car (I also test drove it). So I figured it should have an oil change and I did so 50 miles later.
I put in 4 quarts of Mobil-1 5w-30 and 1/2-quart of Marvel Mystery Oil (I've done this on other cars I've had); and I used a CarQuest oil filter.
Apparently Subaru uses (or will use) a 10w-50 oil that is changed by the dealer to 5w-30 when it gets to the States due to emissions standards. I also have read that the Subaru will also eat oil and thus the reason for the manufacturer switching to the 10w-50. (???)
None-the-less, this is my first turbo car and I want to do right. I don't race the car, but I will drive it hard from time to time after I break it in.
I do a mix of driving with most of it local and I do an average of 25 miles a day. I will try to take the car out on weekends and go for hour or two long drives. I live in Connecticut and most of the local roads here are slightly winding, hilly, about 30mph and there is stop and go driving. So I would say that I fall into the "severe" category of driving
I understand that the 5w-30 should be fine for this time of year through the winter. But if I read correctly, I would want to change to the "thicker" oil in the spring through the summer. I believe that I could switch to, for example, Mobil-1 15w-50.
I also read about oil filters, but see little information regarding the Wix filter that Carquest carries.
If I tip the scale one way, I would say that the 5w-30 and the Wix filter, year round, would be fine. If I tip the scale the other way then a different oil for summer and a different filter with "better" filtering abilities, are in order.
To give you an idea, I had a 1990 Mustang LX-SC that I sold with 113,000 miles on it. It burned no oil and the engine ran quiet and smooth. The underside of the valve covers were still mostly aluminum colored.
I changed the oil & filter every 3,000 miles. The fuel filter every 10,000 miles. The air filter every 30,000 miles. The power steering fluid every year. The brake fluid every two years. The coolant and thermostat every two years. The T-5 trans fluid (ATF) every year (no scoring on synchros @ 89,000 miles) and the differential oil every year and the axle bearings every 50,000 miles.
Obsessive, maybe? Yes!
I'm trying to give you some insight to me so that you can give me some advice regarding oil, oil filters and other lubricants and fluids and I do appreciate it.
Thanks in advance.
Thanks in advance.
