Thin oil, thick oil, synth or dino,
by Cruzingoose
02/13/16 11:25 PM
Compete today? Modernize your skills on own time
by spackard
02/13/16 11:23 PM
Castrol 0w30 leaving Advance Auto Parts
by bbhero
02/13/16 10:53 PM
Oil Change Marathon Today
by BlueOvalFitter
02/13/16 10:01 PM
Raybestos Advance Tech or Police Rotors?
by shiny
02/13/16 09:57 PM
Oil filtration and circulation question
by Doublehaul
02/13/16 09:41 PM
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
02/13/16 09:19 PM
Unused WIX 51372-051815C2 cut & post
by WellOiled
02/13/16 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
02/13/16 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
02/13/16 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
02/13/16 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
02/13/16 07:16 PM
Tsr71, SubaFool, dookchoppa, Formula413, Cruzingoose
56910 Registered Users
49 registered (bdcardinal, B320i, bigdawg74, 11 invisible), 941 Guests and 128 Spiders online.
56910 Members
66 Forums
244670 Topics
Page 1 of 3 1 2 3 >
#2068815 - 11/06/10 12:19 AM German Castrol 0w30 in small engines?
Chris B. Offline
Loc: Colorado
I'm running 0w30 German Castrol in my Toro Lawn Mower and it seem to work well. Can I use German Castrol in all my small engines? I have a 7HP or 9HP Honda Pressure Washer, a 3.5HP Briggs and Stratton lawn edger which is pretty old(12 years or so). Can I use it in the brass pumppart of the pressure washer also or doI need the special oil for that? Thanks!
#2068830 - 11/06/10 12:52 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
Trav Offline
Loc: MA, Mittelfranken.de
I don't know about others here but if its got a small 4cycle engine in my garage it gets GC.My 13hp snowblower starts first time at 0f degrees pull or electric and runs like new,same with lawnmower,power washer and generator.I ran the generator 10 days 24 hrs a day during a extremely cold winter blackout and the valve adjustment was still in spec and shows no sign of wear from that long hard run with seemingly zero oil consumption according to the stick(i did change it at 100 hrs).The oil still looked pretty clean with no metal particles in the filter.IMO you cant do much better than GC in these little engines.
I wouldn't use it in the pressure washer pump,some of the seals may not like the additive package of engine oil.Lowes has a small bottle of pump oil for a few bucks that works fine.
#2068875 - 11/06/10 05:21 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
demarpaint Offline
Loc: NY
Good to know, it will be replacing the Mobil 1 0W30 that was given to me for my snow blower. GC will be the new oil for my blower for now on.
God Bless Our Troops
#2068918 - 11/06/10 07:39 AM Re: German Castrol 0w30 in small engines? [Re: demarpaint]
Bror Jace Offline
Loc: Saratoga, NY
GC is an excellent choice for OPE in all but the hottest temps. thumbsup
The only thing I wish it had is an HDEO add-pack ... but that's a "nice-to-have" and not a necessity in most applications.
No, I would not use it in the actual pump housing. The unit probably calls for a pump oil without detergents to minimize foaming. Consult the manual and/or the manufacturer.
--- Bror Jace
2015 Mazda 3 iSport
2005 Honda S2000
#2068987 - 11/06/10 09:46 AM Re: German Castrol 0w30 in small engines? [Re: Bror Jace]
Trav Offline
GC is SL rated so i'm thinking it has a robust add pack,the viscosity is close to a 40 weight at higher temps so it would be ideal even in the hottest climates.
Maybe someone who knows the detailed specs can chime in.
#2069746 - 11/07/10 02:08 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
Chris B. Offline
Loc: Colorado
What does OPE stand for again?
#2069776 - 11/07/10 05:51 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
hertzer Offline
Loc: Ohio
Outdoor Power Equipment
#2069820 - 11/07/10 07:10 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
Quattro Pete Offline
Loc: Great Lakes
I use GC in OPE that needs to be operated during winter, such as my Honda snowblower. Other stuff, like the lawn mower that does not see very low starting temps just gets straight 30 oil (PYB).
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2071897 - 11/09/10 01:35 PM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
addyguy Offline
Loc: Canada
I personally think GC is a perfect OPE oil.
2003 Mazda Tribute LX V-6, 194k miles.
MM F1 5W-20 conventional + Bardahl B2 additive.
MM MPH2 filter.
#2072515 - 11/10/10 03:24 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
Chris B. Offline
Loc: Colorado
Ok Then! I'll use it in all my small engines. Are there any engine that may not like the GC? Thanks everyone!
#2072549 - 11/10/10 05:47 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
Deltona_Dave Offline
Loc: Deltona, FL USA
Just don't use it in the pressure washer pump. Use an oil made for them (CAT has a great oil), the add packs in automotive oil are not good for the internals of the pump.
You mentioned in a previous post that the Briggs 3.5 had been a little neglected, it may consume some GC at first, but it won't hurt to try it. YMMV
Dave
Emergency Vehicle Technician Law Enforcement
2013 Hyundai Sonata GLS 2.4
2013 Kia Optima EX 2.4
2012 Mazda3 2.0 SkyActiv
#2072563 - 11/10/10 06:09 AM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
gd9704 Offline
Loc: N.E. Ohio
I was surprised to see that my mother's push mower (6.5hp tecumseh) did actually consume some GC over a summer's use. I switched her back to SAE30, which doesn't get consumed.
I do like using the GC for my snowblower.
'09 Nissan Maxima
'05 Jeep Grand Cherokee 4.7
'01 John Deere LT155
'82 Ariens 724 Sno Thro
'12 Honda EU6500is inverter generator
#2072726 - 11/10/10 09:09 AM Re: German Castrol 0w30 in small engines? [Re: gd9704]
lexus114 Offline
Loc: Easton, PA
its tuff to beat the pennzoil straight 30 weight in the B&S motor`s.
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#2073068 - 11/10/10 02:11 PM Re: German Castrol 0w30 in small engines? [Re: Deltona_Dave]
Chris B. Offline
Loc: Colorado
Dave
If it burns oil at first , will it stop as it adjusts?
#2073252 - 11/10/10 05:31 PM Re: German Castrol 0w30 in small engines? [Re: Chris B.]
bigbird_1 Offline
Loc: Winnipeg
Why anyone would put 0W-30 weight oil in outdoor power equipment designed for warm weather use is beyond me.
In a snowblower or generator outside in sub freezing temperatures, sure it makes sense. But in a lawn mower or tiller? Come on.
Page 1 of 3 1 2 3 >
