My Toyota pick up with 3RZ-FE engine developed an intermittent misfire(mostly under load) on Friday.I had a fuel pump failure 18 months ago, so I was worried the new pump might be on its way out?
A few weeks ago I had a dead cell in the battery and when jump starting it, it would start and then stall immediatley but then it was fine on the second start, but it has been fine since I installed the new battery?
Any way yesterday I changed the fuel filter as a precaution(7000km on the old filter) but it didn't seem that dirty.
Then I checked the spark plugs and the leads(resistance okay)but I found No 1 and 2 leads touching right at the coils?
So I moved the plastic twirly things so that they don't touch any more.No 1 and 2 are on seperate colis.
The pick up runs perfectly now?
