My 2009 Toyota Matrix XR automatic 2.4 2AZ-FE has used hardly any oil since it was changed just under 8000 km. (5000 mi.) ago. To be specific the dipstick is down about a third of an inch or about 8 mm. from full indicating oil consumption of around one litre per 24,000 km. (15,000 mi.). The car has 48,000 km. (30,000 mi.) on it and was purchased new. I have used Mobil 1 5W30 and a FRAM 4386 filter exclusively since the first oil change at 5000 km. (3200 mi.). This is consistent with past oil consumption, although consumption increases slightly with shorter trips around the city.
I am very impressed with this and intend to stick with 1 5W30 even though Toyota recommends 5W20 or synthetic 0W20. I am just not comfortable with these lighter oils even with all the assurances from Toyota and elsewhere. In fact, on page 395 of the owner's manual Toyota says: "... An oil with a higher viscosity may be better suited if the vehicle is operated at high speeds, or under extreme load conditions." Since I often use the vehicle under these conditions I believe 5W30 is the right oil and I don't think Toyota or anyone else can disagree given the extremely low oil consumtion.
