Originally Posted By: mattd
These cars seem to be fairly susceptible to torque converter shudder as well. Do you think using the BG fluid would reduce shudder more so than the factory fluid? they also make anti shudder additives that seem to work very well (BG). I have already had the fluid changed once by the dealer at 40k miles because of t/c shudder when cold. That has fixed the problem (for now). I'm just wondering if i should bother putting the honda fluid back in or not.
Thanks for the reply.
When I worked at Mitsubishi, there were common problems with shift flare in the automatic transmissions. The BG Syn ATF always worked flawless in those situations. I don't know what kind of price they were charging you for it, but if it is close to the Honda , or if the AMSOIL is available, we have had very good results with both. I'm not an expert with Hondas, but I know that this box of BG Syn says right on it that it meets Honda specs.
