Originally Posted By: badnews
"as thin as possible, as thick as necessary"
Try to follow this rule.
Basically, Xw-20 will provide sufficient protection for your Civic and will easily get you to 300k miles.
Higher grades will just rob you of performance and fuel economy.
Post proof
That is so much malarkey
Thin oil can lead to cylinder wear, especially if you have any fuel dilution
You're kidding, right? Do you also need proof that the earth is actually round?
Thinner oil results in more efficient operation, period. If the oil isn't thick enough to be suitable for the application, then sure it can increase wear. But as long as it is thick enough to provide adequate film strength during it's life, there's no benefit to going thicker, and plenty of drawbacks, including increased wear.
BTW, scoring of the cylinder walls is hardly the only point of wear on an engine. Wear at the seals is also equally (if not more) important in maintaining engine performance over its lifespan. Thinner oil decreases seal friction torque and reduces wear. It's not all about film strength.
People really to get over this deal that "more=better" and "CAFE=the government wants to ruin our engines".
If you want proof, here's some light reading. Enjoy:
1. “Engine Oil Performance Requirements & Reformulation for Future Engines &
Systems”, S.Korcek & M. Nakada, Proceedings of the International Tribology
Conference, Yokohama 1995, p 783
2. “Fuel Economy Engine Oils : Present & Future”, M. Yamada, [censored]. J. Trib., 41, No. 8, p
783, 1996
3. “Fuel Economy Factors in Lubricants”, J.G. Damrath & A.G. Papay, SAE 821226
4. “Tribology of Reciprocating Internal Combustion Engines”, S. Furuhama, [censored]. Soc.
Mech. Engrs Int. J., 30, No. 266, p 1189, 1987
5. “Fuel Economy Improvement by Engine & Gear Oils”, W.J. Bartz, 5th CEC International
Symposium : Performance Evaluation of Automotive Fuels & Lubricants, CEC97-EL19
6. “Some Relationships Between the Viscometric Properties of Motor Oils & Performance
in European Engines”, J.C. Bell & M.A. Voisey, SAE 770378
7. “Engine Friction Reduction for Improved Fuel Economy”, J.T. Kovach, E.A. Tsakiris &
L.T. Wong, SAE 820085
8. “Engine Friction - A Change in Emphasis”, M.L. Monaghan, Proc. Instn. Mech. Engrs,
202, No. D4, pp 215-226
9. “Engine Friction : The Influence of Lubricant Rheology”, R.I. Taylor, Proc. Instn. Mech,
Engrs, 211, Part J, p 235, 1997
10. “Prediction of the Influence of Lubricant Formulations on Fuel Economy, from
Laboratory Bench Tests”, C. Bovington & H. Spikes, Proceedings of the International
Tribology Conference, p 817, 1995
11. “Lubricant Related Fuel Savings in Short Trip, Cold Weather Service”, T.J. Sheahan &
W.S. Romig, SAE 750676
12. “A Cold-Start Track Test for Evaluating Fuel-Efficient Oils”, G.B. Toft, I.Mech.E/SAE
Joint Int. Conf. on Fuel Efficient Power Trains and Vehicles, London, October 1984
13. “FLARE : An Integrated Software Package for Friction & Lubrication Analysis of
Automotive Engines - Part I : Overview & Applications”, P.K. Goenka, R.S. Paranjpe
14. “FLARE : An Integrated Software Package for Friction & Lubrication Analysis of
Automotive Engines - Part II : Experimental Validation”, R.S. Paranjpe & A. Cusenza,
SAE 920488
15. “Sequence VIB Engine Test for Evaluation of Fuel Efficiency of Engine Oils - Part II.
Stage Selection and Time Factor Determination”, J. Sorab, S. Korcek, C.B. McCollum
& K.W. Schriewer, SAE 982624
16. “Practical Applications of Lubrication Models in Engines”, R.C. Coy, p 197, in New
Directions in Tribology (edited by I.M. Hutchins, published by MEP, 1997)
17. “Friction Modelling for Internal Combustion Engines”, Li Sheng Yang, PhD Thesis,
University of Leeds, 1992
18. “Development of a Friction Prediction Model for High Performance Engines”, K.
Hamai, T. Goto & S. Kai, J. Soc. Trib. & Lub. Engrs., 47, No. 7, p 567-573, 1990
19. “Trends in Engine Technology and Tribology”, M. Nakada, Trib. Int., 27, p 3-8, 1994
20. “Engine Friction Modelling”, R.H. Thring, SAE 920482
21. “Prediction of ASTM Sequence VI and VIA Fuel Economy Based on Laboratory
Bench Tests”, A.K. Gangopadhyay, J. Sorab, P.A. Willermet, K. Schriewer, K. Fyfe &
P.K.S. Lai, SAE 961140
22. “Influences of Lubricant Properties on ASTM Sequence VI and Sequence VI-A Fuel
Efficiency Performance”, A.J. Moore, SAE 961138
23. “Critical Oil Physical Properties that Control the Fuel Economy Performance of General
Motors Vehicles”, M.T. Devlin, W.Y. Lam & T.F. McDonnell, SAE 982503
24. “Reibungsverluste in Verbrennugsmotoren (Friction Losses in Combustion Engines)”,
O.R. Lang, Schmiertechnic Tribologie, 29, p 90-92, 1982
25. “Reducing Friction Losses in Automobile Engines”, M. Hoshi, Trib. Int., 17, No.4, p
185-189, 1984
26. “Engine Oil Effects on Fuel Economy in GM Vehicles - Comparison with the ASTM
Sequence VI-A Engine Dynamometer Test”, S.I. Tseregounis & M.L. McMillan, SAE
952347
27. “Sequence VIB Engine Test for Evaluation of Fuel Efficiency of Engine Oils - Part I.
Aging Procedure for Determination of Fuel Efficiency Retention”, M.D. Johnson, C.B.
McCollum, S. Korcek, R.K. Jensen, K.W. Schriewer, P.H. Neal & P.K.S. Lai, SAE
982623
28. “European Requirements for a Super High-Performance Diesel Oil”, D.C. Colbourne,
Truck Technology International, 1988, pp 108-111
29. “Engine Friction Lubricant Sensitivities : A Comparison of Modern Diesel and Gasoline
Engines”, R.I. Taylor, Esslingen 1998
30. “Fuel Savings with Multigraded Engine Oils in Medium-Speed Diesel Engines”,
Stauffer, Zahalka & Kornmann, Lubrication Engineering, 40, No. 12, pp 744-751
31. “Fuel Economy Improvement by Engine and Gear Oils”, W.J. Bartz, Proceedings of the
24th Leeds-Lyon Symposium on Tribology (published in Tribology for Energy
Conservation, Tribology Series, pp 13-24, 34, 1998, Elsevier, Editor : D.Dowson)
32. “Quantifying the Potential Fuel Economy Benefit of Transmission Lubricants”, D.
Simner, Esslingen 1998
33. “Effects of Valve Train Design Evolution on Motor Oil Anti-Wear Requirements”, J.C.
Bell, paper CEC97-EL02, 5th CEC International Symposium on the Performance
Evaluation of Automotive Fuels and Lubricants, 1997
34. “Engine Friction and Bearing Wear. III. The Role of Elasticity in Bearing Performance”,
E.H. Okrent, ASLE Transactions, 7, 1964, pp 147-152
35. “The Viscoelastic Properties of Multigrade Oils and Their Effect on Journal-Bearing
Characteristics”, B.P. Williamson, K. Walters, T.W. Bates, R.C. Coy & A.L. Milton, J.
Non-Newtonian Fluid Mech., 73, 1997, pp 115-126
36. “Piston Ring Oil Film Thickness - The Effect of Viscosity”, S.L. Moore, SAE 850439
37. “Influence of Piston Ring Gaps on Lubricating Oil Flow into the Combustion Chamber”,
K. Nakashima, S. Ishihara & K. Urano, SAE 952546
38. “Development and Field Test Performance of Fuel Efficient SAE 5W-20 Oils”, A.
Yaguchi & K. Inoue, SAE 952341
39. “Fuel Efficient Lubricants and the Effect of Special Base Oils”, T.E. Kiovsky, N.C.
Yates & J.R. Bales, J.STLE, 50, No. 4, p 307, 1993
These are the supporting texts for the document here:
http://journals.pepublishing.com/content/0w75510650152h34/
