I don’t have the Product Data Sheet form from 3 years ago and older formulations but it looked like the one from a year or so ago except the viscosity at 100C was around 20 cSt. The Pour Point was about -51C and the Flash Point was about 270C just like it was listed in the PDS from about a year ago. Again I’m going from memory as I don’t have a copy of the PDS from several years ago. Older VOAs and UOAs including the AMSOIL test report data support these values. Then a year or two ago the PDS below came out. The notable change from previous is the viscosity at 100C went from about 20 cSt to 17.7 cSt. Perhaps it was a misprint, I don’t know. The table will not paste in properly. The first value is Racing 4T, 10W40 and the second is Vtwin 20W50.
Typical Properties
Mobil 1 Motorcycle Oils
Racing 4T
V-Twin
Product Number 48138-2 48139-0
Engine/Application Type 4-Cycle 4-Cycle
SAE Grade 10W-40 20W-50
Service Classification API SJ,SH, SG/CF API SJ, SH, SG/CF
Gravity, API 30.5 29.4
Density, lb/gal @ 60°F 7.28 7.33
Flash Point (ASTM D92), °C (°F) 253 (487) 270 (518)
Pour Point, °C (°F) -54 (-65) -51 (-60)
Viscosity
Kinematic, cSt @ 40°C 86.0 130.0
Kinematic, cSt @ 100°C 13.8 17.7
Cold Cranking, cP 2900 @ -20°C 2930 @ -10°C
Pumping, cP 11500 @ -30°C 8500 @ -20°C
Viscosity Index 164 150
The latest PDS is on the M1 web site and shows a number differences. Viscosity back up to 20.8, different Pour Point and Flash Points, etc. While it may not be important in practical use, the changes in pour and flash may indicate a change in base maybe a lower % of PAO. For the 20W50 Pour Point went from -51C to -42C. Flash Point went from 270C to 214C. But also note the Flash Point test criteria went from ASTM D92 to ASTM D93. So someone with access to and understanding of those tests can elaborate.
http://www.mobil.com/USA-English/Lubes/PDS/NAUSENPVLMOMobil1_Motorcycle_Oils.aspx
