UCL unnecessary with 0% ethanol gasoline?
Lafayette, LA
I have recently located an ethanol free gas station near my apartment (two actually) and will start running pure gas for the time being. I have been dosing my tank with 4 oz. per ten gallons of MMO prior to discovering the ethanol free gas.
Given that ethanol is "drying", is the use of MMO as a UCL unnecessary with ethanol free gasoline? Or should I continue using it at a lower dose? Or even the same dose? I understand that MMO also helps to clean the fuel system, but I am not addressing that aspect of MMO, only its UCL properties.
