Originally Posted By: 901Memphis
I use Pureone 20195s or Motorcraft FL400s filters, can you guys recommend a specific cutter for either one of those filters?
I am going to need to cut open my old stock blue can Pureone 20195 in a couple of months.
It looks like the 20195 is right on the border line between the two cutters. The Summit Racing cutter above will likely work ok, but might not hit the guide wheels the whole way. I used it recently to cut open an L14459 which is just slightly wider, and it barely touches the wheels, it worked fine.
The HF exhaust pipe cutter works well for me on the 14610 size and is about half the price of the Summit Racing. It would fit your 20195, difficulty can come from trying to hold the slick filter when turning the cutter. Helps if you use a cap wrench or if have a vice.
My suggestion, if you have an HF store nearby, check out the exhaust cutter as it's only in HF stores. Otherwise get the Summitt, it will work.
And yes, I have both cutters, but the Summitt was a gift and the HF Exh cutter was only ~$12 on sale and a 20% coupon. HTH
