I am rebuilding the front end on my Expedition after a broken torsion bar forced me to remove the lower control arms.
Everything except the pitman arm is being replaced with Moog parts with grease fittings, the pitman arm is fine but needs grease also, I will inject it through a needle adapter from below.
I am replacing CV joint boots also with Rockford Duraboots and the U joints.
Here are the questions...
The boots come with green CV joint grease, the boots are the best quality but I have no idea what the grease is or who makes it.
Is it better just to use Redline CV2 or use the thinner green stuff that came with the boots better because its thinner?
For the front end parts I have 4 greases here which one do you think is the most durable
In this relatively heavy application, ball joint failure is well know with these.
I have concerns about using anything with moly in U joints, I have always used Mobil 1 but Redline claims the red moly is fine for this application also.
Redline CV2
Valvoline synthetic w/moly
Mobil 1 red synthetic
Amsoil S2000
Is there anything better than these that will hold up better in NE winters over 10k between re greasing.
Redline CV2
Amsoil S2000
