P125--coolant temp to low for closed loop (temp guage shows normal in the middle of the guage)
P1153--Air fuel sensor response Bank 1 sensor 2 (is this the O2 Sensor?)
p1155--air fuel sensor heater circuit bank 1 sensor 2 (again, is this the O2 sensor?)
p1410--EGR valve position sensor circuit malfunction (???bad EGR valve???)
p1411--EGR valve position sensor range/performance (??? bad EGR valve???)
Thanks for any insight you can provide.
