Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
Mr. Funnel does in fact work!
by TurboFiat124
07/24/16 09:46 PM
Will ATP205 help with a head oil leak
by NattyBoh
07/24/16 09:11 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
27 registered (Branson304, c502cid, alcyon, ag_ghost, carlprop, Anduril, 4 invisible), 925 Guests and 12 Spiders online.
58584 Members
66 Forums
252219 Topics
#2041915 - 10/10/10 01:57 AM Opinion on Grease Gun Needle Nozzles
Techniker Offline
Loc: Virginia
I just wanted to know your opinion on grease gun needle nozzles (I have seen ones that are 18 ga.) and can supposedly be used to penetrate CV boots (and I would assume ball joints). Do you think this would be a good idea to use or will it completely destroy the ball joints? I want to grease the universal joints but I do not have zerk fittings.
Can I also use this to lubricate a universal joint just by shooting grease in every space I can? What is your opinion?
Thank you,
Techniker
#2041959 - 10/10/10 04:49 AM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
mjoekingz28 Offline
Loc: Pearl MS USA
Interesting topic. I'd like to know since my FWD has sealed for life units. Maybe injecting grease can prolong their life.
My dad used a needle on his grease gun on his Ford F150's front end. I think it was the ball joints. You could always hear him coming from around the block since his suspension was so squeaky. They are sealed for life and took a liking to the grease as they are now silent. This has been over a year ago and they're working fine. Truck has circa 150k
2003 Chevrolet Silverado 2500
364ci 5spd 10w-30
"Big C"
2006 Chevrolet Cobalt LS
2.2 Ecotec 4spd 5w-30
"C.C."
#2042042 - 10/10/10 09:00 AM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
Techniker Offline
Loc: Virginia
That is why I am interested. These "sealed for life" units are a joke- how can anything be good for life? This is what worries me when manufacturers claim that ATF is good for the life of the vehicle and why I don't take manufacturer advice as the word of God like some people do here.
So any input anyone?
-Techniker
#2042051 - 10/10/10 09:13 AM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
daman Offline
Loc: Bad Axe, MI
Well yea they would work for CV boots and BJ someplace were you can pierce it through the ribber but a U joint? you may be able to slide it to the one side of one post between the rubber seal and post and shoot some in there.
i use a needle to grease grease less bearings slide it past the dust seal and inner race works perfectly.
they have there place in the tool box sure.
"Always"....Mobil 1
Current fill: AFE 0w30
#2042056 - 10/10/10 09:22 AM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
yeti Offline
Loc: windsor, ontario, canada.
i've been using these needles for many years, on my vehicles, and others on which i did maintenance.never heard of a failure from anyone.
some here will argue that dirt will enter the innards.opinions vary. that's why i only use the fine needle -- about the size of a standard sewing needle. the large guage needle is too large, imo.i've never tried it on CV boots or U joints. good luck.
"there is no sense in having an argument with a man so stupid, he doesn't know you have the better of him." -- john raper
#2042311 - 10/10/10 01:32 PM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
Techniker Offline
Loc: Virginia
And so what happens to the old grease? Does it ooze out of the edges of the ball joint like a regular zerk fitting one or does it just swell?
-Techniker
#2042528 - 10/10/10 06:07 PM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
Jakegday Offline
Loc: fremont nebraska
what would keep the grease inside of the cv boot? do you melt the hole shut?
2001 Pontiac Grand Prix GT
1981 Ford Fairmont
1978 Ford Ranchero GT
#2042545 - 10/10/10 06:23 PM Re: Opinion on Grease Gun Needle Nozzles [Re: Jakegday]
daman Offline
Loc: Bad Axe, MI
-Techniker
if not over filled it'll just swell with the new grease and be good for many years
the hole would be so small it would self seal basically.
"Always"....Mobil 1
#2042605 - 10/10/10 07:26 PM Re: Opinion on Grease Gun Needle Nozzles [Re: Jakegday]
Techniker Offline
Loc: Virginia
This is what I was wondering. I was thinking it might self-seal and even if it doesn't, if you add grease often enough should it even matter?
This brings me to another question. Is there anything you can do to prolong the life of the CV boot? I've heard of spraying it with silicone grease but that is it. Any other ideas?
-Techniker
#2042977 - 10/11/10 02:56 AM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
mjoekingz28 Offline
Loc: Pearl MS USA
I too considered using an armor all type rubber preservative on the boots. But in my owner's manual it says when changing the oil be sure not to let any oil get on the boot. I never understood this statement til I asked. They said it is because oil attracts dust, dirt and sand. When that sediment gets into the grooves of the boot coupled with it spinning and flexing, will wear it out negating any benefit of the preservative.
So, I suspect keeping your CV boots clean is all you can do.
364ci 5spd 10w-30
"Big C"
"C.C."
#2043089 - 10/11/10 08:39 AM Re: Opinion on Grease Gun Needle Nozzles [Re: mjoekingz28]
Techniker Offline
Loc: Virginia
Sigh, I'll go get the pry bar and the breaker bar...
#2045705 - 10/13/10 03:23 PM Re: Opinion on Grease Gun Needle Nozzles [Re: Techniker]
mechtech2 Offline
Loc: Chicago Area
Techniker - PM'd
But those needles are best for roller bearing on wheels. You don't have to remove the rotor, brakes, and bearings to shoot some grease in between the rollers where it belongs.
Forget C/V joints. They are greased for life, and they take special grease, not wheel bearing grease.
If you shoot grease on top of the ball joint socket, it may make some incidental benefit. But drilling a hole and installing a grease fitting on the bottom if far better. Use care. I have done a lot of them, but you can cause problems, depending on the design.
Non greasable ball joints are here to stay - they can be excellent.
