vehicle-----------------06 Chevrolet Silverado HD2500 6.6L, turbo diesel Duramax
OIL---------------------Amsoil AME 15W-40 diesel oil
oil additive------------4 ounces LC20 total over last 16,500 miles
Make up oil-----------1 quart Amsoil ATM 10W-30
Engine oil capacity-----10 quarts
oil filter----------------Amsoil EAO52
air filter----------------PowerCore
miles on oil------------16,500 (apprx 11 months--9/1/09 thru 10/5/10)
Miles on filter----------16,500
miles on vehicle--------58,500
UOA by Oil Analyzers: LAB COMMENTS: Data flagged for observation only; Copper is at a MODERATE LEVEL; Suspect most of the copper may be coming from the lube cooler (as applicable); Potassium is at a MINOR LEVEL; Potassium sources: coolant (antifreeze), lube additive or supplement, solder flux, coating on new bearings, rust preventive coating, or environmental. Your note was taken into consideration; Oil is suitable for continued use. Re-sample in 7,000 miles or 125 hours.
Overall severity of report--------2 (abnormal)
WEAR METALS in PPM:
iron--------------------34
chromium--------------0
nickel------------------0
aluminum---------------3
copper-----------------681
lead--------------------1
tin----------------------2
cadmium---------------0
silver-------------------0
vanadium--------------0
CONTAMINANT METALS:
silicon-----------------15
sodium----------------5
potassium-------------26
MULTI-SOURCE METALS:
titanium---------------0
molybdenum----------0
Antimony-------------0
Manganese-----------0
Lithium---------------0
boron----------------3
ADDITIVE METALS:
magnesium-------------11
calcium----------------3303
barium-----------------0
phosphorus------------1123
zinc--------------------1272
Lube change-----------no
Lube filter change------no
fuel Soot-------------------.1%
Water visc40------------------n/a
visc100----------------13.5
TAN-------------------n/a
TBN-------------------6.62
oxidation---------------29
nitration----------------15
NOTES/COMMENTS: This is a relative's vehicle, which sees a substantial amount of towing. I'm going to recommend he add GM coolant seal tabs to water coolant & change oil every 5,000 miles til copper, potassium issue solved.
PREVIOUS UOA: None.
WEAR METALS in PPM:
CONTAMINANT METALS:
ADDITIVE METALS:
PREVIOUS UOA: None.
