This is currently still up on the Mobil1 Racing store. It shows all the spec they used to adversize. The link to the PDS is now dead.
http://www.mobil1racingstore.com/mo1syatf.html
Mobil 1 Synthetic ATF is designed to provide significantly higher levels of performance above conventional fluids in most domestic and imported passenger vehicles.
The synthetic base oil enables excellent performance even in the severest of operating conditions. It offers outstanding gear shifting and power transfer performance versus conventional ATF fluids. The inherently high viscosity index and stability of Mobil 1 Synthetic ATF help protect against thermal breakdown at high operating temperatures, while still providing outstanding performance at very low ambient temperatures.
Mobil 1 Synthetic ATF combines high-performance synthetic hydrocarbon base oils and a superior balanced additive system to provide significantly higher levels of performance above conventional fluids. This unique, advanced technology provides long drain capability, excellent friction retention, and low-temperature fluidity. Further, it helps to improve overall transmission durability and cleanliness. Mobil 1 Synthetic ATF is also compatible with conventional ATFs.
Mobil 1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles.
* Approved for Allison C-4 applications
* Exceeds JASO 1-A performance standard
* Also suitable for use in vehicles that specify the following fluid requirements: o Audi G 052 025-A2, G 052 162-A1
o BMW LA2634
o Esso LT 71141
o ETL-7045E, ETL-8072B, N402
o Ford* MERCON*, MERCON V, MERCON LV
o All 2005 and earlier GM vehicles**
o Honda ATF-Z1*
o Hyundai SP-II, SP-III
o Idemitsu K17
o JWS 3309
o Kia SP-II, SP-III
o MAN 339F, V1, V2, Z1, Z2, Z3
o Mazda ATF-III, ATF-MV
o Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
o Mitsubishi Diamond SP-II, SP-III
o Nissan Matic-D, Matic-J, Matic-K
o Subaru ATF
o Toyota T-III, T-IV
o Voith 55.6335.XX (G607, G1363)
o Volvo 97340
o ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
* Not recommend for CVT applications, Mercon® SP, Ford Type F
** Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and improved performance in 2005 and earlier vehicles, wherever DEXRON is specified.
Automatic transmissions should be checked for proper fluid levels at regular intervals, and the fluid should be changed at manufacturer-recommended intervals. However, this may vary due to your vehicle's operating conditions. Some manufacturers recommend more frequent changes of transmission fluid under severe driving conditions, such as heavy traffic, hot weather and trailer pulling.
This is what is now on the Mobil1 website with the active link to the new PDS.
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx
Mobil 1 Synthetic ATF outperforms conventional automatic transmission fluids and helps to provide outstanding resistance to oil breakdown and deposits. The inherently high viscosity index and stability of Mobil 1 Synthetic ATF helps to protect against thermal breakdown at high operating temperatures, while still providing outstanding performance at ambient temperatures as low as -54°C. Further, it helps to improve overall transmission durability and cleanliness. Key potential benefits include:
* Helps to improve and extend transmission efficiency, smooth shifting performance and fuel economy.
* Keeps transmissions clean to help provide outstanding performance even under severe driving conditions.
* Significant wear protection which can contribute to long transmission life.
* Helps to provide prompt and reliable lubrication at ambient temperatures down to
-54°C.
* Viscosity retention even under some of the severest heavy duty, high temperature operating conditions.
* Reduced concern in top-off emergencies and excellent leakage control.
Applications
Approved against the off-highway power transmission requirements of Allison C-4.
Specifications and Approvals
Mobil 1 Synthetic ATF has the following builder approvals: Allison C4
Mobil 1 Synthetic ATF meets or exceeds the requirements of: JASO 1-A and Ford Mercon V
Mobil 1 Synthetic ATF is recommended by ExxonMobil for use in applications requiring: GM Dexron IIIH, GM Dexron IIIG, GM Dexron IIE, GM Dexron IID, GM Dexron II, GM Dexron, Ford Mercon, Voith H55.6335.3X, MAN 339 V1, Volvo 97340 and Volvo 97341
