Float is likely stuck, or sending unit is defective. Bang the bottom of the tank with a rubber mallet to try and dislodge it. You can also check electrical connection at fuel tank for corrosion. If that doesn't work, remove the tank and check float. Check sending unit for varying resistance with an OHM meter. Replace defective sending unit if needed
Don't waste your money using MMO, a proper repair is needed here.
