Originally Posted By: A_Harman
I've been running M1 5w30 in mine since new, and am planning to switch to either M1 HM 10w30 or RL 5w30. At 152k miles, it is beginning to show some age. The oil gets dark more quickly after an oil change, and I am hearing a tick in the engine after my last track day at Road Atlanta. Hopefully the tick is a sticky lifter and will go away with a higher detergent oil.
My engine has always had a lot of piston slap until the coolant gets up to temp. How is yours for noise on a cold start?
It sounds like an 80 year old, ill-maintained, diesel engine on a I even pulled out the 160* deal, and put the stock temp (195*??) thermostat back in to help it warm up, and keep some heat in the oil.
BUT, that has not stopped it from performing to the max once it is warmed up (i.e.; lapping days, HPDEs, autocrosses, low 12 second quarter miles @ 114 mph, 32 mpg on the highway in 6th gear, etc.).
