The 04+ plugs tend to have a different problem, they get stuck. The OEM spark plugs are 2 piece and they come apart with the bottom part getting stuck in the head.
3-valve 5.4 L and 6.8 L engines built before 10/9/07 and 3-valve 4.6 Ls built before 11/30/07 found in many 2004-2008 Ford, Lincoln, and Mercury vehicles have an issue with difficult to remove spark plugs which can cause part of the spark plug to become seized in the cylinder head. Ford acknowledges this issue in TSB 08-7-6 as well as earlier TSB's. Ford's TSB does not state that this issue is caused by owner neglect. The TSB provides a special procedure for spark plug removal on these engines. For situations where the spark plug has broken in the head, Ford distributes multiple special tools for removing the seized portion of the plug. The multiple procedures required for the different cases/situations of plugs seized in these engines are explained in the TSB. This repair is covered for vehicles under warranty, however, the Ford recommended spark plug service interval extends beyond the duration of the New Vehicle Limited Warranty.
