Hey guys,
I just joined but have been doing lots of research on here. I own a 2007 honda accord v6 with 50k on the clock. I recently switched over to synthetic oil, giving castrol syntec 5w-20 a try, as seeing this is what a local dealer uses (not a fan of mobil 1, but that is another story)
I've only gone a few hundred miles since the change, and have some questions. The car seems to have a little more valve train noise than before with the regular oil. Is this because it is a thinner oil? It does seem to run *a little* smoother, and may have a little more "get up and go" to it, but that could be my imagination. My concern is the valve train noise. now, this difference is minor, but noticeable. Fuel mileage looks to be about the same as before, maybe slightly less due to minor changes in driving patterns. Has anyone had any issues with this oil in hondas, or any other vehicle for that matter? Or am i just being paranoid? I may try valvoline synpower after this depending on what you guys say.
I know you guys rave about mobil 1 but as a technician i do not like mobil 1 based on what i see when i drain the oil. It comes out like sludge after 5k miles and some of the cars seem to show alot of valve train noise, most notably on GM models. But anyway, if castrol is not what is recommended, valvoline would probably be my next choice.
