We are testing two GE gearboxes and were told to use a ISO 20 Turbine oil. We were unable to procure this in the time we needed to test and used an AW hydraulic oil 32 in it's place. When tested we could not read any oil pressure which should be to our knowledge around 15-20 PSIG. If using turbine oil at ISO 20, will we still encounter this problem?
First time user, appreciate any help!
Ron
Ron
