I have carried pepper spray for about 15 years. I've used it several times at work and seen it used by others. Most of those times it was Bodyguard LE-5 and LE-10. I used the fogger pattern when is was available and now use the cone spray pattern. Very impressive. In my experience it is the spray pattern that makes the most difference with pepper spray. The stream pattern is the most popular, but also the least effective. It doesn't vaporize and therefore doesn't affect the respiratory system like a fogger or cone pattern will. If the attacker manages to keep the spray out of his eyes then the stream pattern isn't very effective. Pepper spray usually takes 10-20 seconds to really start to have an effect. It is only for use against unarmed people.
Tasers work great and instantly if you get a good hit. The disadvantage is they are essentially a single shot weapon.
I think the concern about being sued for using force is greatly overblown, at least in Texas where I live. An individual citizen's concern should mostly be with criminal charges.
The vast majority of people do not have much, if any, non-exempt property. Even if someone managed to win a suit and get a judgment against them they would not collect on the judgment. They can't take your house, car, etc. If it happened at your home they might go after you for your homeowner's insurance policy, but that's all they would get. If they are going after the insurance then your insurance company will provide an attorney for you. Other than that, you are unlikely to be sued. The difficulty in collecting anything from a judgment will keep the attacker from finding an attorney that will take the case on contingency.
Criminal charges against you however will require a substantial amount of money to hire an attorney.
