Originally Posted By: CATERHAM
Originally Posted By: Gary Allan
Harley ..pressure and flow, to that limited dimension, are exchangeable. By that I mean that a given volume at a given visc through a given resistance ..will produce a given pressure.
At all times, if you are below the relief threshold for the oil pump..flow will never be altered. Never. The pressure will go up or down with visc and rpms ..but the flow ..for the most part and ignoring the given "trivials" ..will be in command of all that you see with the needle moving.
Hi Gary,
Hate to disagree but oil flow through an engine, below the relief threshold, increases with the drop in viscosity as the oil heats up and decreases as it cools down and thickens. That's why the oil back pressure that an oil pressure gauge measures, drops as the oil heats up, because the resuling thinner oil is flowing faster through the bearings and the engine generally.
The faster the oil flows the better subject to the minimum oil pressure spec's for the engine.
Reread what I posted ..and I don't think you'll be in conflict with it.
..or get your glasses checked
or do you know how to have a given visc (however you define it) manage to NOT produce a given pressure through a fixed restriction at a given volume (whatever volume you choose at the moment)??
Educate me on that one
