I have a question. I have a 2001 Chevy Z-71 with 5.3L Motor. I went away from DexCool (Not starting that war or debate) lol but after reading the great info on this board I further switched from Prestone Any Color Extended Life To G05. Since the switch my trans temp has shot up by about 20 degrees. I know its been real hot in the south but same temps outside before my trans ran about 20 to 30 degrees cooler.
I have had the trans. filter changed as well as running RedLine D4 ATF and had the temp guage checked on the trans. It is working correctly. Could G05 have any effect on this?
