Wacky. It's the bicycle equivalent of the rotary engine! It doesn't look like it reduces the complexity of the drivetrain much, if at all. The primary benefit is probably cleanliness, but a chain guard can do that too. You'd still have to tie up baggy pant legs so they don't get caught in the pulleys. It will be interesting to see if this idea goes anywhere.
Originally Posted By: Rebecca Boyle
Unlike a typical 10-speed with a derailleur, you won’t feel any slippage when you shift gears — higher or lower gear is obtained by higher or lower placement of the pulleys.
Slippage? Is that the nice way to describe the drivetrain abuse of shifting under power?
