For others:
A rear differential has two systems.
One is to transfer the power 'sideways'. That is the ring and pinion gears.
The actual differential unit is what decides how the power is applied to which wheel. BTW, often it is both.
A FWD transaxle also has two systems together. Usually a helical gear set and the differential system it drives.
