A friend of mine just bought a 2006 Chrysler 300 and, when I hooked up my Equus 3130 scanner to it, I noticed LTFT Bank1 at around 10 and Bank2 at around 18. Under load the LTFT values drop to between 5 and 7.
I did a quick check for intake leaks by introducing propane (from an unlit torch) around the outside of the intake ducting and manifold and did not notice any change in the STFT values. I will do a detailed check of the intake sometime.
Anything else I should be checking?
