I can see where the confusion is coming from. Amsoil's big claim to fame of exceeding all the specs of the brake fluid is right if the temperatures you are trying to beat are dry boiling temps. But ah lass, they are not. they are the wet boiling temps of the fluid.
It's much easier to make a fluid with a high dry boiling point than a high wet one. So what manufacturers tend to do is just make those and say, "Wow, look at me and my 6000 degree boiling point for 5$ (Wilwood 570 is 573dry/313wet for $15)." The much more expensive and time consuming thing to do is make to do is make a brake fluid with a high dry and wet boiling point, one that doesn't absorb water and break down as quickly, like Castrol SRF (590dry/518wet) which is $75. So you can see, you generally get what you pay for. Business as usual.
Oh so...the main point is the cheaper fluid just passed the DOT 3 requirement for wet boiling point while advertising its amazing dry boiling point, and the second fluid went way beyond all of it... if you can boil that fluid, you drive a Bugatti Veyron with brakes of a Pinto on the Nurburgring.
