Originally Posted By: robshelton
If you are doing a 2.2 4cyl its easier. Drivers side has a spring clip "C" holding it in the transaxle, so after removing the axle nut, unbolting the ball joint, popping the hub off the ball joint, pushing the axle thru the hub and swinging the hub assembly out of the way just slide a medium sized screwdriver behind the inner joint and wiggle. If it doesn't pop out easily, rotate the axle a bit and try again. It will come out easily when it lines up right. Be careful to not damage the dust seal! You will need a large pry bar or similar to push the control arm down so you can get the hub out of the way.
Passenger side can be a bit harder as mentioned above. The inner joint does not have a clip holding it in but the bracket mentioned above holds it in. Ideally you just remove the large snap ring that holds the axle in the bearing in the bracket and pull it thru. The snap ring is large and a
Rob,
Thanks a lot for your advice! I was having great difficulty with the job until I remember this thread and read your instructions again. After following your instructions to rotate the driver's side axle, I was able to get the half shaft out easily in under a minute! The passenger side confused me for a while. For a few hours I experimented with pounding, a slide hammer, etc...until I noticed the snap ring. I had looked for the snap ring for a while but could not find it (as everything is covered with grease on this car, every component is leaking). But once I found the ring and removed it, the axle came right out.
Unfortunately I also found slightly leaking tie rod ends and ball joints on this car as well. Good thing they were leaking though, as using the pickle fork to separate the tie rod end resulted in puncturing the boot-- I guess there's a way to use a pickle fork without damaging the boot, but I am not experienced enough to do that. The car is still up on stands now, as I am having trouble getting the lower ball joints out, but I think renting a ball joint pickle fork should take them out? Any advice on removal of the lower ball joints?
Thanks again to you and to everyone else for all of the help. Definitely could not have done the job without the advice.
